Junk Collector
⭐Supporting Member
Truck of Month
I have an '88 Ranger 4x4 with the 2.9 and A4LD.
I have had no overdrive gear in about the last 5,000 miles - that is, when I shift into OD, it either stays in 3rd (about 3500 RPM at 65 MPH) or it drops down to about 1,200 RPM when you let off the gas.
Now I have heard that the A4LD's have a solenoid that controls when to shift into OD, and if it craps out, you suddenly don't have that gear. The guy at the tranny shop told me that this is not true until the last few production years for that transmission. He said that my OD band is probably hosed.
So I'm curious as to whether what he said is true or not. It seems kinda unlikely (to me anyway.) The truck's only got 85k on it and it has NEVER been beaten on, does not make any noises or slip in any other gears, and had the tranny flushed and filter replaced recently (last 10,000 or so.) I lost OD really quickly too, like it worked one night, driving home from work, and didn't the next morning on the way back to work.
Any insight?
Any insight?
