a/t Transmission shifting
asidpara
I have 87 Broncoll. It has a flat spot at 25 MPH speed. The transfer to the next gear is rough unless I slow down. I have changed oil, filter, vacuum module. Any suggestion?
replace the vacuum lines to the shift module may be a cracked hose
agreed.. check vacuum lines.
also check the vehicle speed sensor. Take it out, check the plastic gear on the sensor and in the t/case
