A/C is working fantastic!
I can only get mine to go down to about 52 degrees. But when it is 95 and humid, 52 is just fine for me.
Have you had your F250's a/c serviced by your dealer at any point? DO you notice any temperature change when your sitting still idling as opposed to driving down the open highway in an adverse way? It should be cooling down to at least 46-50 steadily. I just serviced a 2002 F350 last week during a day with 105-110 heat index, and it cooled to 46, right before the cycling switch cut the compressor off, and even still, it went to 50 or 52 and started cooling back down. If you haven't, i suggest you take it to them and have them check for a TSB (Technical Service Bulletin) concerning a revised amount of R-134a.
AS FOR THE REST OF YOU.........No a/c is no problem. My 78 150, 92 expo, and the 88 ranger i drive dont have a/c, but thats why they have windows that work. Thats also why my truck as a Sony head unit in it, so i dont have to listen to the sound of the wind rushing past my ears. Sorry guys, your not gonna convince me that A/C in an automobile is an absolute necessity. (ok so the ranger and expo really do have a/c its just not working, but the expo will be getting it soon. Chicks dont dig wind damaging their hair when you take them out)
Umm, your air conditioner turns itself off when you mash the throttle. You get the same power with or without it.
And in most cases you need to MASH it too the floor. In Texas AC is a necessity and because I drive a 2.3 power is down with the AC on. I don't like to drive my Ranger with the pedal floored all the time.
I bought my 93 in 95 and in 96 I decided to fix the AC/Acceleration problem. I insatalled a Stewart Warner Vaccuum switch and a relay on the compressor coil. This particular switch is NC at any vaccuum above 9Hg. Below this level it opens and the relay shuts off the compressor.
My truck spends 90% of its time on the interstate and here in Abilene (even during Rush Hour) traffic flows smoothly.
This system has worked flawlessly for over 10-years now.
My 10-cents worth
For the record, my AC is working flawlessly in this effin' hot humid weather we've been having. What is this, summer or something?
Last summer, I took a trip in my old ranger (no AC) to help a friend move 250 miles away. Two people, a regular cab oven, and 100 deg temps. My poor mitsu tranny decided it didn't like living anymore that weekend. Ever had to rock a truck back and forth to get the tranny to unjam itself in the middle of an intersection? Poor thing....
Enough rambling.
G'night
-krug
It is fine as long as you can stay moving, back when I was in high school it got to 136 fairly regularly inside the cab of my Ranger and it took about 20 min of stop and go to get up to a respectable speed to get some circulation going. I did my time, and I ain't going to go thru it again for a dd if I don't have to.
Having the windows down doesn't do much good just sitting in traffic and even driving about 30 mph around town. Trust me, I drive all day with the windows all the way down and I STILL sweat my ass off. Then again, I've never been very tolerant of hot weather, I do much better during the winter. And even though I could crank the volume to hear the stereo, I would rather not go deaf by the time I'm 23. (And yes, the sound level of just the wind alone at highway speeds is enough to make you go deaf over extended periods of time.) Yea, A/C isn't a necessity for everyone, but it is for me.
AS FOR THE REST OF YOU.........No a/c is no problem. My 78 150, 92 expo, and the 88 ranger i drive dont have a/c, but thats why they have windows that work...Sorry guys, your not gonna convince me that A/C in an automobile is an absolute necessity.
Yeah, I've found that keeping myself plenty hydrated with fluids and having the windows down is usually fine without the need to turn the A/C on. I use the A/C once in a while(still works great!), but for the most part, I save the extra load on the engine and get along without it.
T.
A/C works on every setting but "Off"!
I'm glad to see some of you have great working A/C. My problem is it even works on any of the vent settings. The only way the compressor clutch disengages is in the "off" position. The local auto parts guy thought it might be the clutch interrupter switch. A $12 investment proved that wasn't it. Does anyone have any other thoughts or experiences to share?
getting the A/C fixed was a good investment:rolleyes:, had it done right before road trip to yellowstone ( from san deigo ) and in 110+ heat, it really is nice to not bake :mad: as you drive down the road
$900 to fix im gonna use it
wow i don't think i would have spent $900 for air. i would have suffered. but we did spend $600 on the wifes last car for a/c because it had a habit of eating window regulators.
i thought i was spending $400 because the guy said the compressor was fine, and he was just going to throw a new belt on and charge it. Got a call back and hour later, " uh yea, your compressors bad " So its either i spend $400 dollars and get nothing at all or spend 500 more (new compressor) and get working A/C
$500 for a new compressor? Does that count the gold plating?
I bought one for my Exploder for around $200.
If that guy didn't find the compressor leak BEFORE putting 3 lb of R-12 in there, he owes you 3 lb of R-12. Your system has a leak, and if he was claiming there wasn't one, he was wrong. Refrigerant doesn't just vanish or wear out. It leaks. And if there are no obvious external leaks, it's either the compressor or evaporator (those are the components with hidden parts).
It depends on where you live and how much driving you do. Driving for hours in 105º heat is exhausting, even with the windows rolled down. Have you ever tried driving in 113º-117º heat? It is miserable.
Both my 1995 4.0 and my 2007 2.3L turn off the a/c under heavy throttle. The 2.3L does it a lot better though.
the compressor didnt leak it had mechanical problems,and he charged it the second time without charge
but still its rediculous
I drive 14 hours a day. I will not do it with out working A/C, period.... especially when tarping 48,000# of drywall on a 105* afternoon in oklahoma,or untarping kiln dried lumbar in Dallas. If the A/C goes bad the truck parks until the company gets it fixed.
OK, I think I see what happened.
That wasn't $500 for a compressor. That was $500 for a compressor and a condenser, flush, and inline filter, which is considerably more reasonable. If you don't do all this, all the grit from the failed compressor will persist in the system and grind up your new compressor in short order.
It's called "Ford Black Death."
