Howdy yall,
I've had my 99 4wd ranger for about 6 months now. Love the thing, but my initial plan of doin the usual 302 you commonly see has changed quite a bit. Bottom line up front: I'm curious if anyone would know of how significant of a difference in fuel economy a pair of super duty 05+ Axles would be compared to a bronco 44 up front + ford f150 8.8 rear-end?
my incentive to go the 1 ton route would be to have better peace of mind when hauling a maximum of about 3000 pounds worth of steel, scrap, ammo, or any combination of. We're talking about a flatbed setup, keeping 4wd, and gearing it no less than 3.73 no more than 4.10. Leaning towards 3.73 as I already have my TDI ALH long block that will be in my build plan, and I will be swapping in a zf5 and atlas 2.0 5:1 transfer case. Definitely some fab work with some cross members, maybe some frame gusseting here and there, but a SAS is going to involve some fab work regardless of these other moving parts I have to consider (tdi swap, zf5, atlas, flatbed, etc). I'm goin big or goin home. So, the question still stands: with all other things remaining the same, how much should I expect AVERAGE fuel economy to go down with super duty Axles as opposed to the bronco/f150 swap? This Is one of the last major parts of this build plan I really have to workshop and get some genuine input on, so I appreciate any knowledge or experience. Other ranger tdi swap build threads have allegedly reported up to 40 mpg cruising and to my understanding, that wasn't with some super deliberate goal of achieving those numbers. Thanks in advance,
Matt
Matt
