99 Ranger Check engine light
dmize
Michigan
I have a 99 2.5, stick. The VSS went bad on the way home the other night, and the speedometer quit, and the ABS,Check engine lights come on. After i replaced the VSS the speedometer works and the ABS light went out. But after disconnecting the battery the check engine light will not go out. Any suggestions. The engine is running great.
Thanks Dave
sometimes ull need to clear the code with a scanner to turn the cel light off.
