99 moutaineer abs light on
WConke
Onalaska WA
Front hub bearing went bad. After replacement the abs light stayed on. How do you reset light? And can you read the codes without a code reader? The local parts houses only do engine codes. I saw one link but it was bad Help
Thanks Wayne
I had an ABS problem and took it to a dealership. They charged me $96 to find the code, so try to avoid that. If you aren't having any braking problem beside the light, try disconnecting/reconnecting the battery or the fuse.
I got bearing grease on my ABS sensor that messed it up, reading a code 27.
Joey
