2.5L ('98-'01) 98 Ford Ranger 2.5L running rough and no power.
Doomgaze
10+ Year Member
💻 TRS Socials
Deep South
TX - USA
Vehicle
Drive
2WD
2.5 (4 Cylinder)
I was coming home from work the other day and all of a sudden began to lose power. I pulled over and turned the truck off and check fluids etc. Had a scan done at O'Reilly's: P0171: System too Lean (Bank )
P1506: -
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
I've replaced the coil packs and the fuel filter so far but no resolution. I had to work all week/weekend so I had my dad check the truck out. He checked the fuel pump and the timing and saw no issue. He didn't check the spark plugs/wires besides the #1. Anyone have any idea aside from those thing that I should check at this point? I know there are many things it could be but just ideas for trouble shooting.
Thank you for your time.
Can always try moving the #2 or #3 wire to #1 or 4 to see if the misfire follows the wire. Obviously the other end of the wire needs to be in the right plug on the coil pack..
But considering it's misfiring on neighboring cylinders & also showing a lean condition id probably be taking a look at the intake gaskets.
With those symptoms and codes I would suspect the pre cat oxygen sensor before spending a bunch of money on other stuff... if it's old change it, if not check the heater circuit and fuse supplying power to it, unless there's a bad vacuum leak somewhere...
Yeah, I will be doing that. I have new spark plugs and wires and fuel injectors to replace on the truck this weekend. So, definitely will take a look. The gasket isn't very old though to be honest but will definitely look and replace it after I put in new fuel injectors. Will update after I do the job if the issue was resolved.
I will take a look at those and yeah I was thinking there could be a vacuum leak somewhere which will be fine to find...
Update: Put it back in time and still running rough. Will change sparkplugs/fuel injectors next.
Do one at a time so you know what did or didn't fix it.
Although that would be a good idea to do one at a time it would also be a complete pain in the rear... unless you have really dainty hands dealing with the drivers side spark plugs requires pulling the upper intake off which is what would be needed to change the fuel injectors... that said just changing the passenger side plugs is very easy and would fix an ignition issue if that's what it was.
With the right combo of wobble extensions, regular extensions, and universal joints, one can change the driver's side plugs without removing the manifold. I did it at least once but I'm also used to working in difficult places that one can barely see what they are working on, using a mirror where everything is backwards, or doing it all by feel.
Yeah I have the wobbles and what not to do it but like y'all said. I have to take the upper intake off for the injectors. Mind as well just do both jobs at once and replace everything at that point.
Knowing my luck though... prolly will end up being something worse. Dropped valve or something hell who knows.
