- Sep 22, 2007
- Michigan
- 2.9L
- Manual
- My credo
- A legend to the old man, a hero to the child...
97 F250 HD 460/E4OD
I moved it yesterday and noticed the ABS light was on.
Today i moved it and noticed the speedo not working, O/D light was blinking, and it wouldnt shift out of 1st (unless i shifted manually), once in second it kinda sounded like the lockup kicked in.
Anyways...there was no check engine but i scanned for codes...i got the following...
KOEO- 452 VSS (vehicle speed sensor) problem.
KOER- 116 ECT out of range (expected, the T stat is bad so it wont warm up
311- AIR system not working (expected, tube rusted out, new was unobtainable, deleted system)
632-
536-
Im thinking the speed sensor is bad...i did notice the speedo "twitching" slightly (very slightly) last time i drove it.
Am i correct in this diagnosis? Idont wanna just shotgun parts at it espcially with how part quality is these days.
Thanks
632-
(R) E4OD – Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test (This one concerns me....not sure what this means?? Trans problem?) |
536-
(O,R,M) Brake On Off open or shorted to ground – BOO (this also concerns me since the ABS light is whats on....brake light switch malfuntion? Lights still work, interlock releases....cant see this killing the speedo and not allowing shifts |
Thanks
