97 ext cab 4.0 camber question
that_one_guy
The end of the Oregon Trail
So i took my truck to the alignment shop to see how off my camber is. So i dont remember what it was but they said if i could do a inch and a quarter leveling that it would be dead on. There for i have seen that people just use washers under the spring to lift. what size washers do i use?
So if I get this correctly you CAN add 1.5" to level it out and that'll correct your camber problem? usually it works the other way... you first level the truck and then correct camber to the proper spec....
Take a look at the tech section for the washer lift...
http://www.therangerstation.com/tech_library/WasherCoilSpacers.htm
Still, take a look in the "lifting for cheap" section, there's a couple of options in there....
If the camber happens to be negative, a small bit of lift from washers can easily fix it, yes. Positive camber is a different story however (and is usually what results from a leveling lift).
