chilsam
turn signal effect
rmmber that the relay thros out an on off circuit to the pump!
That's what I figured out from the diagram, but its nice to have some confirmation! The third wire goes to a warning light on the gauge cluster. When the switch is tripped, the power gets diverted to the light, instead of the fuel pump.That would be good if it turns out to be the problem...if you cut any wires make sure you leave them long as possible...forgot what the switch looked like...apparently three wires involved and not just a clip...one source says dark green/yellow and pink/black wire need to be jumped...
Sorry, I didn't have time to post after I got home from work. I went right back out with the wife.Crossing eyes...lol
From your silence it appears it either wasn't the problem or you are out busting the speed limits with your new found power...hope it's the later...but at least you eliminated one more possible source...
Perseverance...it pays sometimes...
Sadly, that was not the problem. But, as you say, I eliminated one possible problem.
I think I may venture out to a few junkyards tomorrow in search of a new (used) PCM. I know I have to find another one from a 4 cylinder/5 speed, but does it have to be a 97? Would a 96 work?
I could probably pull a fuel pump, too...
