96 ranger wisconsin build
disturbedgoat21
fremont wi
1996 For now
so at the moment i have a 96 ford ranger 4.0 5speed 4x4.
what i have:
14in foa coil overs in front
raptor firber glass front clip
35in baja crawler on bead lock rims
68 302 mild built
what i need:
cut and turn dana 44 ttb
ford 9in rear
rework engine cage
3or4 link in rear
coil overs for the rear
now what im currantly looking for is weather i should run with a c4 tranny wit dana 20 tcase from a early bronco or if i should use the zf5 out of my old mans 89 f250 with inline 6?
here is some pics of what im currantly working with
  • 96 ranger wisconsin build
i was planning on doing in right behind the lower ball joint seams to be the most simple way to do it
I pull 17. Limited by the hood. Axle would pull almost 20 but wanted low ride height. Cut-N-turn sure does help the up travel, limits down though. Air it out. LOL
sweet ya sadly i say i wanna get air but im in wi so there not much open desert or anything so il probably be stuck with crawling and jeep trails :bawling:
