lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
I know that this really belongs in the Fullsize Ford forum... but since I've noticed some posts languish on there for days... I'm posting it here too in hopes of a quick answer since I have to put my dash back together PDQ.
Trying to get my tach wired up in my F-150. It's been bothering me that I don't have a tach in it since I got the truck. I can drive a 5-speed fine without one, it doesn't really affect me all that much after having driven pretty much nothing but manual trans trucks since I was 17.
Buuuuttt... the grinder has been singing and the welder humming as I try to prepare for another nasty winter by getting a plow fabbed together and on the truck. And since I had to tear the dash apart to do some wiring for the plow, I thought, hey, what better time than now to wire up my tach. Problem is, I'm on a time crunch and I can't find the right wire. Or in other words I have tomorrow (Sunday) and possibly Monday before I have to put my dash back together so the truck is driveable.
I have a ground, illumination and key-on power all picked out to tap into. I just can't seem to find a tach signal wire. I know there pretty much has to be one in the dash because the wiring should be there for the gauge cluster if Ford would have been bright enough to put a gauge cluster with a tach in a truck with a manual trans instead of in auto trans trucks.
I know that I can tap into the wire in the engine compartment where it comes off the coil. But I already have a dozen or so wires run through my firewall and would rather not poke a hole for another wire if I can avoid it. I tried looking in my Hanes manual for an appropriate diagram (lol, I should have known better), and I tried doing a couple searches online for the information (but everything just tells me to hook to the coil or to pick up the tan wire with yellow stripe). Problem is, I can't find a tan wire with a yellow stripe at the gauge cluster. I know I picked up the tach signal off a tan/yellow wire in my Ranger back when I wired that up and the wire went right up to the gauge cluster.
So can anyone give me a clue as to what wire would carry the tach signal to my gauge cluster??
Truck: 1995 F-150 xl, 4x4, 4.9L engine, 5-spd trans
Tach: (not that it makes a difference) Autometer Sport Comp
Thanks!
Thanks!
