95+ 3.0 flywheel swap in 93 3.0?
01cobradude
Does anybody know if a 95 3.0 ranger flywheel will swap in a 93 3.0 ranger? I know they are both 6 bolt flywheels. The only difference I know is the clutch is larger on the 95+ 9 1/8" vs 7 1/8 on the 93. The reason I ask is I accidently ordered the kit for a 95-00. Do they have the same outer diameter and everything to fit in the 93 m50d?
the crank mounting is the same for all 3.0 ohv (excludes yahama 3.0and ohc)
as for crank mounting surface to disk mating surface im unshure...
Anybody know about the ring gear diameter if it is the same?
That sucks. The guy I got the clutch from said they were different 93 161 teeth & 95 162 teeth and I exchanged it for the 93. Oh well I can always upgrade next time.
