94 mazda b2300 info on replacing timing belt
mich5187
I own a 94 mazda b2300 pu,2.3 L ac/ps and with manual 5 speed.Need more information on how to remove timing belt cover,have a chilton but so far doesn't seem to help.I have removed fan and fan cover,water pump pulley,loosened ac pulley,taken out screw from cover and bottom nut from cover, still doesn't seem to want to come off.Do I need to pull crankshaft pulley?It seems to be behind this pulley.Would appreciate the help and better yet a diagram or picture to help me also.
You have to remove the crank pulley anyway to change the belt. I believe autozone has detailed instructions with pictures on-line, that may help. Set the motor to tdc before you remove the crank pulley, it will make things easier later.
94 mazda
Thank you I'll give it a try and let you know. Thanks again
Got it (the timing belt) on Thanks a million have one more problem though
Thanks a lot guys got it on and got it runnning.Now having to replace the serpentine belt tensioner, broke it last night trying to tighten the belt up a little. Oh well live and learn, anyone know the size of the bolt and were it is located on the tensioner and maybe the cost of the darn thing..It's a 94 b2300 pu with power steering ,ac.
thanks again
the bolt on the tensioner is a torx. I think it's t47.
Should be a T-50.
