94 Explorer Slow Acceleration
double check for clogged cats or exhaust. i had a very similar problem that turned out to be clogged cats. try pulling the o2 sensors and driving it that way, if the cats are plugged, this will let pressure out.
Oh yeah, I forgot to add that I did the Burp thing. It made it alot better, but it still does it so I will probably have to do it again. Will air in the coolant system hurt anything? I can't see how it would unless it causes the engine to overheat
It is to your advantage to remove all of the air out of the coolant passages. That said you probably will never get absolutely ALL of the air out..ever. If you try real good though and do it well your truck won't overheat. Thats also why I said to keep the heat on for the next couple weeks because as you go up hills and have to downshift at times it will, in a way, do the burping for you, as long as you keep an eye on your levels (both in the radiator AND the reservoir). The way this could affect your performance is your engine's computer reads hey..this engine's running hot, lets go conservative here for a while to keep from blowing up. When the sensor's reading everythings ok then it'll let it run right.
A quick trip to an exhaust shop will rule out an exhaust problem.
Call a few and see if they do a radiant thermometer test.
Some will throw that quick check at you for nothing if they aren't busy.
O2 sensors could be an issue, here's an interesting article covering both those subjects:
http://www.asashop.org/autoinc/july97/techtotech.htm
I'd check the IAT and ECT http://fordfuelinjection.com/?p=28 and http://fordfuelinjection.com/?p=29 since that's free if you have a meter, clean up the IAC and TB, throw plugs (inspecting each's condition) and wires http://www.custompistols.com/cars/articles/sparkplug.htm at it for if need be.
What size tire you running? I'd go much smaller diameter tires if it needs a set. That is a tall ratio. Might be most of the problem. 94 still uses the cable speedo so it's easy to correct, whether you re-gear (I envy that talent) or change tire size.
No sense buying new rubber if the tires are good and you've got a set of gears.
http://www.therangerstation.com/tech_library/Speedometer_Change_From_Tires.html
http://www.therangerstation.com/tech_library/Speedogear.html
Good luck with it. I'd do all the free and cheap stuff first.
Don't fix what ain't broke.
A thermostat is <$10, sounds like you may need one. Or test it, http://www.2carpros.com/articles/how-to-test-an-engine-cooling-system-thermostat
I don't know what got into me, I'm a linking fool this afternoon.
I truly appreciate the links, I will first try cleaning the IAT and ECT, since that won't cost much. I already bought a thermostat, they're to cheap not to replace. As far as the tires go, they are brand new with the nipples still on them, so they will have to stay for awhile.
That's a good point. I didn't think that it running a little warmer than usual might throw the computers off. It has never reached the red or even past the "L" in "NORMAL" and since I burped it now it stays within the "ORMA" so I'm not worried about it overheating. I would just like to get it running as efficiently as a 4.0 can (even though efficient may not be the best word to describe a 4.0)
