- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
- Manual
1994 Ranger 2.3, 5SP, 2WD, 90K miles
I'm getting annoyed that my brake pressure bleeds off when I'm sitting at stoplights, often ending up with the truck starting to roll if I'm not paying attention.
I don't have any fluid leaks anywhere and the levels aren't dropping so I'm sure the system is at least still a sealed loop.
At this point, I suspect it is the brake booster, but I'd like some opinions.
Tests:
- Start truck, let idle for ~30 sec to build vacuum in the booster
- Press and hold brake pedal while shutting off engine
- Result- pedal holds steady for about 15 seconds, then VERY SLOWLY starts pushing back. If I had to guess, I'd say a rate of about 1/4 inch every 15-20 seconds.
Second test
- pump up brake and hold pedal while starting engine
- result: pedal sinks 2-3 inches, a little lower than when I'm normally driving and stopping
Other notes: I don't hear any hissing or anything, but that doesn't mean much as the engine makes enough noise to drown out any light hissing, but there's nothing obvious.
Also, Where the master meets the booster, there is a rust trail going straight down the front/bottom of the booster in the shape of what was likely a brake fluid leak or spill from the distant past. It's rusted and pitted, but I don't see any holes best I can tell, it feel solid there. It is also dry, no detectable oily film at all, bone dry so that tells me it's pretty old, or at least older than when I redid the engine bay and washed and cleaned everything about a year ago.
Do you guys think I can conclude that it is the brake booster with a small leak, or would you focus more on the master cyl?
As always, appreciate any feedback you may have.
!@# Awesome picture as a reward for reading my crummy post!
Tests:
Second test
