94 A4LD won't shift to second
Kansas
Hi all have 94 extended cab with a 3.0 and a A4LD that won't shift to second in drive. I can shift it manually and it shifts fine. Any ideas what my issue is? Thanks in advance
Mileage?
Have the bands ever been adjusted?
Is the trans fluid up to level?
Has the trans fluid and filter ever been changed?
Transmission Modulator Valve connected? This could be the cause.
Mileage?
Has 145000 miles on it. As far as I know the bands have not been touched. Fresh fluid and filter change. Fluid was dirty not burned and absolutely no metal in the pan. Good vacuum to the modulator.
