- Aug 23, 2025
- startford
- State - Country
- NY - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- Manual
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 235 65 15
If have 94 4.0 ranger 4x4 have to start 2-3 times to get to start rpm spike to 1500-2000rpm then dies once it does start idle surges between 500ish and 2000ish rpms when I press the pedal it surges between like 3000 and 2000 rpms
The whole fuel system from pump to injectors has been replaced fuel pressure stays beween 30-40psi, all intake gaskets have been replaced. Iac, tps are also new. When I unplug iac it try’s to low idle for a second then dies. I have checked all wiring no shorts, when I hook up scanners and do the koer test I get 411 and 412 codes. Seem to surge less when the ect and iat are unplugged but still not right. When I use scanner all sensor data looks good other then the o2 sensor show constant high and low readings in conjecture with each other unless I unplug iac then stays at rich .4v
Edit: for get to mention new coil wires and plugs and yes they are hooked up on drive side the right way
