I think I've seen this problem on here before but can't recall any potential diagnosis other than problems with the charcoal canister that I already removed from the vacuum system.
Every once in a while my truck decides to surge up to 3k when I put the clutch in to shift after traveling upwards of 45 mph. It'll maintain 3k for a few seconds and bring itself back down to idle at about the same pace the revs drop after a start-up. Restarting the truck seems to solve the problem. Sometimes it just stops on its own after one or two shifts. This has only happened a handful of times these last few months so I don't have a whole lot more details.
I'd take it on a few more drives to get video but it was pissing coolant this morning and I've yet to go looking for the cause.
The following mostly unrelated parts have been replaced: clutch, driver side head, top end gaskets, rear main seal, oil pan gasket, battery, TPS, MAF, O2's, IAC, coil, plugs, wires, #4 injector
