chode_rider
So, been trying to figure this out fir a few months now an d figured I'd ask the ranger station. My 94 2.3 has a lack of power when you stomp on the gas, just won't get up and go. Seems to Rev normally at about half throttle but just kinda dies out when you go full throttle. However the idle is smooth and normal. Code says it's running lean. After I did a lot of tune up stuff I checked the fuel pressure, which is quite low - 40 psi with key on no start, 30 psi at idle, 40 w regulator vacuum hose pulled. I replaced the fuel pump but no change in the fuel pressure.
Here's what I've done so far:
Spark plugs
Air filter
Fuel filter
Deleted egr with aftermarket plate, put a screw in the pipe off the exhaust manifold
Fuel pump
Generally checked for vacuum leaks by spraying carb cleaner
Got rid of stretch in throttle cable w zipties
Checked compression which is good
My next thoughts are replace the fuel cap in case that's not allowing it to build enough pressure, and pull the intake manifold to clean it. (Intake manifold is kinda filthy with oil, because the truck was upside down for a minute back in September - original cause of this issue)
At this point I think the problem is the lownfuel pressure. According to my book it should be putting out 60 psi. I read somewhere on the internet that the computer assumes it's getting 60 psi and adjusts air accordingly so that would cause a leannl condition. Any ideas what else could cause pressure besides the pump?
thx
Spark plugs
Air filter
Fuel filter
Fuel pump
thx
