93 Ranger that's been parked. Plans to be a daily
I had to replace the master cycl in mine twice... And I did my clutch not that long ago and used that same method worked fine sry man and yes the master cycl was annoying just cause ya end up a stuffed up under the dash if I can help in anyway just let me know
Edit: you can try another way of bleeding but I never had much success are you in Ohio??
Well I'm open to all options, i haven't gotten to touch it since I messed it up. But no I'm in Chattanooga TN
Sent from my HTC One_M8 using Tapatalk
Little update. I got the truck towed to a shop to go over it. Gonna have them try and figure out the clutch problem. Hopefully I'll have it back in the next few weeks to see what's left to be done.
Oh dude please more pics of that Ranger!!!
Hopefully soon mfernandes! Just got a call from the shop today. Got the clutch fixed. Getting a new battery done, new maf sensor and brakes while they're at it. Should be good to go through my local emissions when I get it back. And then yes more pictures hahah
Since it has sat for awhile don't be surprised if you have things keep breaking/leaking and failing. My 86 Bronco II sat for 12 years, my 94 Probe sat about 10 and the 94 C3500 sat about 3. Worst thing that can happen to a car. Things will work fine for a while and then they fail. Keep plugging away and in a short while the bugs will be worked out. I use all of mine for daily drivers now with no problems.
