92 sas
Will the james duff radius arm kit work on the full width f150 dana 44's? The dana 44 I purchased is already set up for radius arms and coils... I will be installing it on my 92 Ranger that looks identical to yours.
I myself don't have any personal experience with the JD radius arms, I'm running stock radius arms from a 79 F-150. Although I have seen guys run the JD arms on a full width axle
I am also planing on running a dana 44 out of a 79 f150 that came with the radius arms still attached. I would like to use them to save a little cash where did you order your radius arm frame mounts and are those the progressive rate coils from JD?
what gears are in the d35? i need some 4.10's
NICE work on the ranger. i love it. looks good. need action pics!
The radius arm mounts, you can't order them...I made them. And yes those are the JD coils, I like them alot
Gears in the D35 are 3:73 unfortunately...
thanks alot, hopefully this weekend I'll get some pictures of it in action.
someone is looking for a d35 chunk... hm, let me see who PM'ed me about it.
hold please... BEEP....
Looks good, but I'd be careful of that front driveshaft angle, looks a little steep...
SVT
What bushings do you have?? I doubt it will be enough, but the 7* bushings combined with with higher RA mounts will give you a better angle at the axle yoke :icon_thumby:
SVT
SVT
I have the 7* bushings in it right now, the angle actually looks worse in those pictures than what it really is... it doesn't bind at all so it will do the job for now
