- Aug 6, 2007
- Shangri-La
- State - Country
- GA - USA
- Drive
- 2WD
- Manual
- Tire Size
- Round
- My credo
- Alas poor Toonces; I knew him well.
could it be the switch in on the dash? its one that pulls out a click for dash and running lights, and a second click for headlights
No, the combination switch would be suspect before the light switch in the dash. But the combination switch has been replaced already, so let's rule it out for now.
With headlights/running lights off on the driver side, i get only the front signal. With headlights/running lights on, on the driver side, I get no turn signal at all, and the indicator on the dash remains constant on.
and in the problem socket, I did see power thru black, only when running lights/headlights were on.
The problems that you're having strongly suggest a grounding problem, especially the reading of power in the ground wire on the bad side. And I wouldn't rule out a bad connection(s) somewhere in the circuits.
If it were me, here's where I'd go next with it.
First, look at the front driver lighting grounding point, G102. This is a ring terminal bolted to the radiator support above and inboard of the driver headlight. There's a splice up from terminal, which connects the individual ground wires to the headlight, turn signal, running light and engine compartment light. Make sure the ground ring is tight and not corroded. Look over the harnesses in this area, checking that there hasn't been any boogering done to the wiring. I have seen splices get rotted, but I'd save the splice until after the next step.
Second, I'd really go through the rear light wiring carefully. It's good that you put in a new socket, and I assume that you also redid the old connections for the previous replacement socket. The grounding point for the rear lighting is G103, and it's actually bolted to the driver's fender well in the engine compartment, about midway. So check that grounding point, but I'd be more suspect of the wiring harness in the rear of the truck. There's a black 8-pin connector (C401) behind the rear bumper near the driver side frame rail; this has the rear lighting circuits. Start there, and go over every inch of harness to the driver side lights, looking for breaks and non-stock splices. There is a factory splice on the black ground wire close to the connector, and this splice should be unwrapped and checked for corrosion.
The fact that the socket was replaced before is a red flag, as there was a problem and somebody has been into the rear wiring before. And a lot of times with lighting problems, it's a past trailer harness installation that's the cause (and may have even been removed, but the boogered wiring remains). Focus on anything that doesn't look stock, and if needed, I'd even pull the tail light harnesses out, and lay it on ground plugged at C401 in order to troubleshoot things better.
Don't get flustered; it's usually something simple, but easy to overlook. Good luck!
