For Sale 91 Ranger $500 - Dittmer, MO
RayInStl
10+ Year Member
⭐Supporting Member
St. Louis, MO
Well, that didn't work. Let's try something else!
I have waaaaay too many projects and need to clean up my property some, so this Ranger is up for grabs. Truck is 2wd, long bed, standard cab.
The bad:
  • No engine. Had a 2.3L but was pulled due to rod knock. I have either an 85 (FREE) or a 97 (additional $200) engine that can go with it. Neither are correct for this truck, but will mount up and can be made to work. The 97 has the ECM and harness. 85 does not. Both are known-good engines
  • Rust above both rear wheel openings. Very fixable
  • Rust on lower tailgate, also very fixable.
  • Some cracking on dashboard
The good,
  • Great M5OD manual trans
  • All glass in excellent shape
  • Body is VERY straight. Other than the rust mentioned, no other big body issues
  • Frame and floors are rock solid.
  • Brakes work
It would make the perfect platform for a 5.0 mini-truck, or throw a 2.3 in it and have a great little truck.
