- Mar 9, 2020
- London, Ky
- 2.9 V6
- Manual
- Total Lift
- stock
- My credo
- Speed doesn't matter if you can't keep it on the track.
Hey guys. So I have installed this alarm and it works. Just the basics, no door switch trigger, doorlocks or horn. Has shock/movement sensor. So far all I have connected are the, Orange, White, Black, Brown and Red wires. I have also connected the 2 black starter interrupt wires to the Pink starter wire (goes between the clutch pedal and starter relay I guess) as per diagram. (Links below).
Here's the problem, starter interrupt doesn't work when armed.. i can start the vehicle etc. with the alarm blaring.
I have tried to connect the Yellow Ignition Input wire (from Alarm harness) to the "Ignition" 1 & 2 respectively to see if this works.. this results in no cranking whether armed or disarmed. I have tried testing the Yellow on the Red/LG and the BR/Pink, both of these stay HOT in Start mode. No luck.
One last thing, there is an Orange (alarm harness) wire that says, "(-)500ma Ground-when-armed-output" I have this connected to a ground. I have no idea if this is correct.
I have a Multimeter and a fair sense of what I'm doing, but obviously there is something wrong here.
I have the link to the Bulldogsecurity page with the legend of all the wires for my Ranger.
Here are the other links to this alarm system that show what I'm talking about... any help is appreciated!
https://www.directeddealers.com/manuals/IG/Avital/N3100 2011-12 print.pdf
https://www.manualslib.com/manual/752201/Directed-Electronics-3100.html?page=15#manual
PS. I have tried searching this forum already and read tons of good help, but I can't find anything specific to my issue. Good chance I missed something though, I always do lol
