89 2.0 ranger
whitey
TN
2000 f250 4 doo
I have a 89 2.0 ranger need wiring diagrams for and how to install A 88 thunderbird turbo coupe and need the wiring diagrams for this as well. I am new so I need all the help I can get. Thanks in advance.
going from carbed 2.o to 2.3t help
OK guys guessed at the wiring ang got it running only if you spray carb cleaner in it. took a test light to injectors and they light up on both sides but no flashing or blinking while cranking. What have I missed or what do you think my problem is?
You may want to post this in the Forced Induction forum since they deal with Turbos and their associated setup/problems
Did you wire in the high pressure electric fuel pump? FI needs it your carbed 2.0 didn't have one. If so check the pressure anyway, your injectors will still fire if there isn't any/enough fuel or pressure. It won't atomize out of the injector so you won't run.
I have the fuel pump wired in and all of the sensors and the fuel pump is working. Should the injectors light up on both sides with a regular test light with the key on or while I am cranking? If I need to I can post in another section... Thanks again
Bump Need help.....
