- Aug 23, 2025
- WEBB CITY
- State - Country
- MO - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.9 V6
- Tire Size
- 15
I have an 88 ranger xlt 2.9l dual tank. I have done many things to it I’ll list below. I have also tested lots of things I’ll list below.
The issues I have are as follows; it has erratic idle, sudden drops in rpms when idling and when accelerating. Happens more when under heavy load and acceleration. I also have an issue where if I just hop in the truck start it up and go drive when engine is cold it will sputter maybe 10 times until it warms up and then it stops sputtering. Usually it doesn’t sputter after it warms up unless I turn off the truck and then turn it back on. Then it only does it once or so. I also can’t get the truck to accelerate above 60. It seems like it has a lean or rich mixture or something like that when accelerating. It accelerates slowly as well
Replaced:
-distributor, including cap and rotor
-ignition coil
-spark plugs and wires
-fuel injectors
-high pressure fuel pump
-fuel filter
-upper and lower intake gaskets
-any other gaskets you can replace when doing intake gaskets
-map sensor, o2 sensor, coolant temp sensor, intake air temp sensor, oil sender
Tested:
-compression test was stock compression on all cylinders (190)
-vacuum test was good. I believe it needs somewhere between 20-24 hcg and it was 23
-iac valve I’ve replaced and it didn’t change anything so I put the old one back on
-throttle position I replaced and didn’t change anything so I put old one back on
I want to test my fuel pressure at the rail but none of the fittings I’ve tried will fit my ranger for some reason. I went to oriellys and their kit didn’t fit.
I do understand as well that any of the parts I’ve replaced could be bad out of the box so any comments or suggestions are welcome. I just want to get my truck running well and I can’t seem to get it to run. I’m chasing my tail it seems like
Replaced:
-ignition coil
-fuel injectors
-fuel filter
Tested:
