'87 Ranger 2.9L ~Low Fuel Pressure/Emission~
I am mobile! Repaired check valve in fuel accumilator/reservoir and fixed other line restrictions I didnt know about. As expected, runs like a Rat outta hell. Thanks for all the insight and recommendations. Excellent forum.
Forever Obeying Responsible Drivers...
What did you have to do to repair the check valve in the fuel accumilator/reservoir and fix the other line restrictions, as you mentioned that you repaired??
What do you think was the main problem that was causing your Ranger to not run properly??
Do you think it was starving for fuel because of a plugged fuel accumulator filter, or do you think it was because the fuel accumulator's check valve for the inlet of the accummilator/reservoir was bad??
Upcoming TRS Events
