87 b2 silnoid wires
how did you get it running ?..did you jump the stater solenoid with the key on?
did you check the little wire on the solenoid for battery voltage with the key in start position?
if there is no voltage at small wire with key in start postion then you need to check th neutral safety switch or ignition switch for voltage when key in start postion ....MAKE SURE TRUCK IS IN PARK AND WHEELS ARE BLOCKED
