'87 B2 Electrical Door Issues...
Coloradorangers
Both window motors work. Driver's side sounds like it's off track and I'm working on it this afternoon. Pass side had no window switch, pulled one from JY and window went down....but it ain't a goin' back up. Can't find wiring diagram to hot wire it to go back up, any help?
Also driver's side switch won't activate pass window from driver's controls. And lastly the power lock only works on pass side. Need new actuator?
maybe you got a bad switch. check your grounds
Tore most of it apart lasty night. 1 motor was bad, 1 actuator was bad, 1 bad switch, 1 set of cut wires at the grommet in the driver's door.....ugh!!!!
