87-88 turbo coupe intake.
92dangerranger
Kentucky
I'm doing a turbo swap into my 92 ranger. I ended up buying this intake thinking it would work with the valve cover from the 86 turbo coupe. I painted it to match my valve cover but the intake is two low. So I was just wondering how much you think it is worth? I cant use it and i need to know what you guys think it would sell for?
I really wish i could of used it with my valve cover. It would of looked so good.
All you need is the 87-88 valve cover. Another option would be the Ranger upper intake. I think it's a little bit higher and will clear your valve cover.
I like the valve cover that is on the engine now. It says Ford turbo fuel injection on it. I just thought it would be cool to make the intake that had 2.3 EFI match it. I'm going to use the intake that i already have on the engine now. It is just the smooth type that came out of the 86 turbo coupe.
I guess if i really wanted to use it i could have a spacer made.
Plywood wooden spacer! :headbang:
