- Oct 30, 2013
- Hampton Roads, VA
- Manual
You are insane for asking about running to computers, but that is beside the point. Take care not to read too much into anything I have told you to do, and to read nothing into what I haven't told you to do. I have not told you to remove any of the old system yet, but that doesn't mean it will be used.
You are running a manual trans right? That means the only thing the PCM is doing is controlling the engine. You don't need the 97 computer to run the Turbo-coupe engine, it has it's own computer for that, which is what you need to use. You unplug the 97 computer and leave it unplugged. I don't want it deciding to try and do something and end up interfering.
Yes, beefed up stock 97 Ranger manual transmission, so your assumptions are correct! I apologize, I was thinking the PCM and ECU were the SAME thing for some reason. I'm wrong. Again. Do you mind explaining the difference or how they work together? (A link would suffice) Just so I can learn MORE about what "we're" doing here! Haha.... Once running and I have everything UNDERSTOOD, I should be able to do as I please. Once I do something ONE time mechanically, I never forget!
Also, I guess I should point out that most of the gauges, the tach, oil pressure, engine temp, etc won't work with this wiring. Those need to be connected separately, but they aren't needed just to run the engine. Fuel gauge should keep working though.
These can just be tapped into SONEWHERE via "pickup wire", power, ground, etc.... correct?
THANK YOU! You're the man!!!! Sounds like PERFECT instructions WITH wiring diagrams! Couldnt ask for anything more and couldnt be more appreciative!
So myuestion STILL IS, after everything is spliced in where need be, do I plug the PCM BACK IN? OR DO I LEAVE IT UNPLUGGED? Kind of a grey area that doesnt make much sense, but thats why im trying to get AWAY from this FOR NOW!!!
(And the PCM is the box on the passenger side, engine side, upper firewall.... Correct?)
