- Oct 31, 2008
- Automatic
Truck is started and runs until normal temp. will run all day sitting in the yard and not run hot, throttle blocked to about 2500 rpm, good heat with some bubbles going into overflow tank. Thermostat seems to cycle open and closed as needed, Radiator same temp top, middle and bottom. When you drive about 1 mile heater goes cold, temp rises rapidly and coolant is pushed into overflow tank till overflowing and onto ground. Temp gauge will slowly come back down and intermittent heat will return. Truck will be about 3/4 gal. low on coolant. New 195 Thermostat, New 13psi Cap Thanks for any help!
