85 bronco ii tranny fluid
boredom zero
hey im trying to check the transmission fluid in my manual, 4x4 bronco ii. i have been looking at the tech stuff on the website and i know its a fm 145 tranny, but i don't now which bolt is the correct one to pull. there are two smaller looking bolts on the drivers side of the tranny, and one 11/16 bolt on the passengers side. i have no idea which one is correct and dont want to check any until i know because i dont want to mess with any internal. thanks for any help if u can thanks
It's about halfway up the driver's side, somewhat centered on the trans. It's a big old thing too. If you go look at the tech library, the fill plug is clearly visible in the drawings of the transmission.
thanks i found it and my worry was answered, the fluid was fine and NOT low or empty. Its runnin like a champ couldn't be happier unless i put a bigger engine in. once again thank you
