84 ranger 2.3 heat only works on high
RangerFabWorks
The O.G blackwidow67
⭐Supporting Member
💻 TRS Socials
Lexington
NC - USA
Vehicle
Drive
5.0L
my heater only blows when my switch is on high. what is the problem?
Sounds like your blower motor resistor has gone bye-bye. Luckily, this is an easy fix.
where would it be located?
It is in the blower box, closer to the engine than the blower motor. It is the only other thing with wires going to it other than the blower motor itself.
ahh ok thanks
+1 on the resistor and your plug is probably melted to the resistor so it would be a good idea to replace that too. And also the part # for the resistor is RU-318 and the part # for the plug is S-630. The manufacturer is Standard Motor Products.
