- Feb 13, 2011
- Acworth, GA
- '84
- Automatic
So, after letting it sit over night, it cranked right up. Started and went to high idle, I let it sit on high idle for a few minutes and then tapped the gas to let it kick down to a regular idle. Moved it back closer to the garage than it was where it stalled last night. It sat there idling for a few minutes and then it stalled. cranking it up, it seemed to stumble and finally caught but then quickly died. cranked it again and it was more temperamental but started and idled for a bit.
I'm thinking the TFI module is shot, so I'll go out and get one of those. I'm pretty sure it's not a fuel or air problem right now, so it's got to be spark.
It's also painfully obvious that the brakes need to be bleed more. I damn near hit the garage when pulling up closer but luckily, it rolled to a stop just short of the back door.
I'm more encouraged today than last night.. that was a big letdown to crank it up, drive it and have it conk out in the middle of the back yard. There's still hope to get it on the road before I go back to work on Wednesday.
the fuel tank and sender and some other little parts from Rock Auto should be here for the weekend to install.
