8.8 differences??
Twisted4x4
1988
198
A buddy of mine has a 94 Bronco with the 8.8 rear. Well his rear end went out and we are goin to look for another one tomarrow in the parts yard. Im not real fimilar with the 8.8's. What all were they used in and will one from a truck fit under a bronco or not?
well yes and no , yes a 8.8 will fit out a f150 i think from 1987-1995 not real sure on the years , but you will have to make sure the axle gear ratio is the same as your front axle or it will break something , one way to tell what gear ratio it has is to look up the axle code on the tag thats on your drivers door jam , it should tell you what ratio you have in a shop manual , good luck and hope it help
Any full size F-series will fit the Bronc, just make sure it has the same gear ratio, as stated :icon_thumby:
SVT
