8.8 Cross shaft
ZSK
Jacksonville, FL
While removing the cross shaft I noticed that the retaining bolt was broken at the base of the threads. What is this actually called and is it a Ford only part? I need to pick one up before my gear swap next week.
Im sure its a Ford only part. I dont know the exact name but im sure if you call it the cross pin retaining bolt they will know what you are talking about.
Napa sells them. Part number 635-1023
Carquest has them for $3. Ford and GM share the application.
or if you have access to a machine shop, you can make it free and use a socket head cap screw:icon_thumby:
runnert
