fordguy65
I have a 78 302 from a F-150 and a 69 302, They both have the front sump oil pan and the dipstick oil tube runs into the front of the timing cover case on the right (drivers side of the front motor). I just ordered the 5.0 double sump, oil pick-up tube and dipstick kit from Summit Racing(FMS-M-6675-A50). My question is can I still use the oil dip stick in the front of the engine or will I need to relocate to the rear left side like on the later model 5.0 engines. The late model 5.0 has the dipstick tube running at an angle into the block below the rear coolant frost plug. My plan was to use the 69 engine and accessories and keep it (wiring) simple.
Thank you,
Chas
Thank you,
Chas
