600hp 2JZ Swap: Discuss
2JZ is
31" long, pulleys to starting edge of bell housing (end of block), so 4" longer the 302/5.0l V8 which barely fits with short pullies and E-fan, could change to shorter wider radiator in front of rad support, maybe get enough room
27" tall, bottom of pan to top of valve cover, 302 V8 21" tall, can do a body lift
30" wide (edge of stock twins to edge of intake manifold), 302 V8 19" wide
This ones a killer in a Ranger engine bay
Have to move steering shaft and lose heater box, exhaust to outside of frame maybe
Keep in mind i will also be relocating the battery and i am doing a electric ps rack so i will have plenty of real estate
ok so some unfortunate news. my daily driver just had the clutch slave go out. 2j project is out while i source another daily and get my current ranger back up and running. i still plan to do the 2jz ranger swap but life has other plans for the next month or 2. i will keep the thread updated
Ok gents.... Been a crazy few months but unfortunately its time to move on. Im selling my 2jz shortblock (dm if interested) and moving onto smaller projects around the house and mainly getting my current daily ranger finshed restored. Im only 19 and the parts for this engine are just too pricey and while it was a good deal i wasnt super crazy about the 2j from the start. Hoping to get a ford flex limited and play around with the 3.5 ecoboost while still getting my truck fixed.
Sorry to hype everyone up then disappoint you but ce la vie.
If your after cheap parts, gm is the way.
Still gonna break the bank being any sort of performance enthusiast though.... regardless of brand. Shit gets out of control in a hurry lol.
its not as much that as it is that i need SO many parts. the engine i bought came with no wiring no sensors no oil pump no alternater etc. i need so many parts and i also realized that even tho it would be rad im only 19 and saving money is more important right now.
Im begining a 2jz swap into a ranger. Ive seen one other person do this here but its super old and none of the photos are accessible now. I plan to document this very detailed and keep it updated here. I would love to answer any questions and i am open to any advice
DETAILS:
2JZ: (currently in progress)
gsc stage 1 billet cam
gsc valves
gsc conical springs
8.5:1 compression diamond pistons
Manley H-beam rods
stock crank
67mm turbo
-all parts are capable for 1000-1400hp but i plan to run it around 600 i just want it overbuilt.
RANGER: (open to suggestions and have not purchased yet)
just a beater for under 1k preferably under 500
first gen 80s for the look, electronic simplicity, and weight
single cab short bed 2wd
will be running a full custom wiring harness and ecumaster emu black along with a amu 7 dash.
CD009 Nissan transmission
Rear end is in the air - How much power can a 8.8 hold? can it be built?
Hello, new here and seen this an couple year old thread. Have you had any updates on the swap? I'm thinking of doing the same. What rear end did you use and what front end and motor mounts you used?
