scott5640
Davenport FL
does any1 know how to take the little handle things off?:icon_confused::icon_confused:
theres a little screw under the handle. like look at the door face on and just under that handle ull see teh screw.
You can't take just the handle off. The whole panel comes off. 4? screws, I believe.
there are 2 screws you can see just behind the pull handle, remove them then give the handle a pull, the whole thing handle and surround will come off then there are 2 more screws in the front and back of that handle you have to remove then it unclips and comes off.
flying brick got it right for the handle itself.
To take the panel off, there is 1 or 2 screws under the grip panel. There is also one at the back of the door down low. the door panel then lifts directly up ho get it off.
