Chackler , 1 Minute Ago
Hi all, another common 4x4 shifting problem. 2003 ranger XLT 4.0 manual. New motorcraft 4x4 control module, new transfer case shift motor, fuses good. I can shift into 4hi, but the shift motor does not continue turning to 4lo. I have verified this by removing shift motor but leaving it plugged in and having someone turn the selector switch with brake on while I watched shift motor turn. It will shift to 4hi,sometimes on its own go back to 2wd or just stop at 4hi. I have sifted through the forums and can't find this particular situation. I know on the earlier models there is a speed sensor to make sure you're not going over a certain speed before it shifts into 4lo, does my model have anything like that? Thank you
	 Welcome Visitor! Please take a few seconds and
