4x4 Issues please help
TmoneyRanger
The 4x4 light will in my 1993 ranger not come on when i press the 4wd button! I hear some noise in the Moudle behind my seat when i press the button but no light! Do you think i could try tapping on the shift Motor for the 4wd to see if it will free something up like they say about the Ford Explorer?? Also there is a 10 amo fuse in the fuse box and its supposed to be a 15amp but the fuse looks fine could any of these ideas be the soultion if not someone please point me in the right direction!!! Thanks:icon_thumby:
I'd start with giving that shift motor a good knock. Also, I know you don't have to do this, but I always make sure my transmission is in neutral before I shift it into 4x4. It makes sure that the drivetrain is free of tension before making the t-case work.
As for the fuse....not sure if that would cause a problem with the 4x4, but you should definitely change it out for the proper one.
