- Dec 11, 2016
- Princeton, KS
- 4.0 V6
- Automatic
I have a '03 4.0 4x4 that is having transmission problems, and it's going to be a when not if I have to dump some money into it. But...
I have a '98 4x2 that has a good transmission, same ( bad ) motor.
Hell, I have a '98 4x2 with a 3.0 to rob from as well. They are both my parts trucks.
Overheated and then a pair of cold center cylinders on the right bank in both '98's. Guess '98 wasn't that great a year.
Is it just wishful thinking that I could swap trans and drive shaft between the 4.0 trucks? Every drive train dimension I can find matches, including the wheelbase.
Has anybody done this? I could see going 4x2 to 4x4 being a nightmare, but 4x4 to 4x2 would just be not using the 4x4 selector and removing the front drive shaft in my mind... or am I missing something obvious? I'd be tickled if somebody said I could pull the tail cone from the 4x2 and the transfer case without having to actually swap transmissions.
