well fellas ive got the probe seats in. now i understand why no one ever puts probe seats in rangers. what a freakin pain. all in all it wasnt that bad but theres no way id ever do it again, id just get a set that directly bolts in and be done with it.
the positives to having them in are i have a ton of leg room, way more then i need and im not even back all the way with the seat. the seats are unbelieveably comfortable, i adjusted the bolster to tighten in on my sides, adjusted the lumbar etc, super super comfy seats! i honestly cant say enough about how comfy they are. what a difference!
the negatives to having them are the drivers seat isnt centered on the steering wheel, sits a good bit to the left, the tracks are so wide that i pushed them as far over as i could towards the transmission hump but it still isnt centered, its not so far over that its a problem but it is something that i noticed. both the drivers and passengers seat are so wide that they make contact with the door panels, nothing to where i have to worry about it breaking something but you definately gotta give the door a good push to get it shut all the way.
i also changed out my steering column before installing the drivers seat. im 3 for 3 on the column, i now have turn signals, i can now start the truck via the key and ive also got the tilt. cant be any happier about that. i do have one problem with the new column, its a cruise control column so the wiring for the horn is different so i dont know which wires to cut and splice for the horn to work. anyone got any experience with this?
o i forgot to mention, i went and looked at the explorer fenders again and took some measurements, just by some rough measurements it flares out a half an inch wider than the rangers does and also it flares a full inch higher than the rangers does. after taking these measurements im really not thinking that 50 bucks a fender is really worth it for that little of a difference but who knows if i can get both of them for 50 bucks i might consider it since they are way straighter then mine are.
tomorrow im gonna get my tires swapped around and try and get a front end alignment.
ive got a few questions...
will an explorer driveshaft work on a ranger? im interested in doing the 1 piece driveshaft conversion but my local yard only has explorers, no newer rangers.
i currently have a 3 inch body lift on the truck that i havnt got around to removing yet... if i do the rear shackle flip will this allow the shackle to clear the bed or will i need to cut the bed regardless?
i was reading in the tech library about swapping in explorer springs in place of the rangers. one guy was saying that he did a mixed spring set up with both the ranger and explorer springs and gained 3.5 inchs of lift. i have a 3.5 inch lift block in the rear of my truck so would this be worth doing to get rid of the block and just have a hybrid spring, or would the spring be so stiff at that point that it wouldnt flex good at all?
are there any other things i can steal out of an explorer that would be of benefit to my truck or is it basicly all the same? i read that the explorer has 31 spline with a trac lock but with it being so much wider is it worth doing since the donor explorer still doesnt have disc brakes?
passenger side probe bucket
drivers side probe bucket
reenforcement squares i cut up
