October_V
- Aug 8, 2017
- Automatic
Finally have to ask for help.
I have a '99 Ranger, 3.0L, 4x4. 4r44e problems.
No signs of life from the trans, no noise, no movement, nothing.
I have replaced the valve body gasket, original was blown out.
I have a completely different valve body in it now.
All the solenoids check out ok on the meter and the shift engagement rod is on the manual valve.
The shift lever on the console does move the engagement rod
I can roll the truck as if its in N in all the gears except P.
I believe I read that if the TPS (throttle position sensor?) is bad that can keep a auto trans from working.
I have dropped the pan 3 times now and am loosing my enthusiasm.
Looking for some direction to go next before i pull the trans out and do a complete tear down and rebuild.
thanks
thanks
