4L SOCH timing chain
7aawilson
Forum Member
Kennett Square
PA - USA
Vehicle
Drive
Stock
Stock
30 inch
I got a really good condition 2006 4L SOCH, I've heard mixed reviews on the timing chain guides though. I heard that their really prone to breaking, but that ford also revised the issue in 2003. My trucks only got 90000 miles, do yall have any recommendations on what mileage I should do the chain, if at all?
I wouldn't change the chains or guides unless you start to experience problems.
The hydraulic chain tensioners are another story. Those should be replaced... as maintenance... around 100k. Don't buy the cheapest on Amazon. Motorcraft or Cloyes are my choice.
Probably the best thing you can do is use good oil and filters and be very proactive on oil changes. Motorcraft filters have an anti drain back valves and are my choice.
The truck has low mileage and has been in the family for a while, i just got it from my grandpa, and I'm fairly ocd about keeping up with it. I do oil changes every 5000 with full synthetic mobile 1 and a stp premium filter. How easy are the guides to do? I'm fairly comfortable with diy things, I've done things like a cv axle, harmonic balancer, and spark plugs on it
I believe if you keep good tensioners in it by replacing them proactively as Uncle Gump suggested, you won't need to change the guides. The guides break (from my understanding) when the hydraulic tensioners fail and allow the chains to slap around destroying the guides.
