4bt help please
lifted94
Can someone please tell me what I would need to get to put a 4bt in my 94 ranger. Its 4x4 with sos. It has a 70 dana 44 and rear 9 inch out of a bronco. The truck is my daily driver. I need to know what tranny and transfer case to use. I would like the truck to stay a manual with the 4bt swap. All info on the swap would be very appreciated thank you.
Find the rare ford adapter and run a ZF/NP set up.
Then mock up the engine and notch the oil pan around your diff or lift it sky high and not have to alter the pan.
It has 13 inch lift now
Oh I would say thats plenty lol. I put the engine as far back and low as I could just to keep center of gravity down. Its a pretty easy fit in there, just have to get rid of the giant starter thats in there. There are a few ranger swaps floating around different sites.
run whatever trans and t case the engine is setup for...
typically they have a a setup for a t400 behind them. i would use a chevy case like a 241 drivers drop on something like that. run whatever chevy manual you like as well.
if its setup for a ford...same thing.
Remember if you use Chevy to either tilt the engine or your transmission will be tilted
