475,000 mile F7 rear axle
Ok. That's good that the ring gear size doesn't play into it. Then I'm good. Because I got 4.10 from front to rear.
Thanks Toledo.
Gear ratio is gear ratio. Ring gear size doesn’t matter, only the ratio does. You could have a Dana 28 up front and a 9” in the back and it won’t matter as long as the gear ratio is the same.
Nice. Thanks everyone. I am driving the truck now. The ominous sounds coming from underneath the truck are gone. But I'll reserve judgment until I've had several days to drive it.
I didn't have a good quality torque wrench to use on the leaf spring bolts. I made these reasonably tight. But not very tight. How tight do you guys make your leaf spring U-Bolts?
You should be fine. Use a paint pen and mark the nut and corresponding spot on the plate. Check a couple times to see if they move.
A kids crayon would probably last long enough to see any movement. Or use some finger nail polish...
Since you don't have a torque wrench, before applying the paint pen I'd drive it a few days and retighten. If you are able to tighten, drive it a few more days and repeat, until they seem to stay tight. This will give everything a chance to settle in and retighten before applying the reference mark. From that point you should be good if you just check the mark occasionally.
Good timing Josh. Yes. I tightened the leaf spring U-Bolts twice more since then. This rear axle replacement seems to be successful. There were no less than 4 different abnornal sounds coming from the drive line. All these sounds are gone now. I lean my head out the window to listen when coasting, and all I hear is tire noise on the asphalt.
Oh.............I see. It's leading me into a false sense of security. As long as this false sense of security is a 10-year stretch..........................which it will be................Yes?:)
