4 banger with 33's
I'm running 4.10's and 31's and I run about 3000rpm in 5th gear at 65mph, so I think it's about perfect, if you're running 4.56's and 33's it'll probably be about the same...
Hay my buddy has a 91 ranger 4x4 with 192k on its 2.3. It has stock 4.10 gears, we just put on 33in tall 14 wide boggers on it. its a dog off the line but still drives ok an holds 55 fine. Off road it turns all 4 alsome in 4low. 3rd gear will sling mud far in the air. Putting better gears in your may b good idea. hes going with 5.13s. he want the gear to pull hill climbs, an running 35 some day. but for now its not that bad..... Ive driven worse haha
Good luck
Scott
I have a 94 2wd 5 speed 2.3 and I have 4.56 with 33x1250's. I can take my buddys stock 3.0 edge til about 50 mph. The only thing that sucks is the MPG and the lack of use of 5 gear, especially if it is windy.
What kind of mileage are you getting?
for 33s on a 2.3 thats driven on the street a lot I would actually suggest 4.88s. The 4.56s are ok but still a little low for the 33s. 4.56s are actually about perfect for a 31 inch tire on a 2.3 and will pull about 25MPG. The 33s with 4.88s should be about the same and 5th gear will still be useable fine on the highway.
I'm getting 12-14 MPG. The 4.56 were put on with the 30's and were awesome. I want to put new ones in, someone suggested 5.13? or something like that, but the 4.56 work for now.
